2G Stutters into 4th gear
GSXvsTSI
147
14
Aug 11, 2015
Pleasant Grove, Utah
I just built the transmission with IPT shift kit, rebuild kit and all the clutches. I'm using a forced four shift box plus and when I try to shift from 3rd to 4th it jumps all over the place and takes a while to engage 4th. R,1,2,3 work perfect but I have a brand new motor and haven't hit boost either. Any help would be very appreciated!
I just drove it some more and its shifting a lot better. Almost like there was an air bubble that was jacking the shift up. Could an air pocket have caused it? Everything is electrically correct so it'd have to be that seal.
I had only shifted into overdrive a few times, so I bet it was just breaking in. I did lube everything up and I soaked the clutches for a while but they sat in the trans for 1month before they moved. The fluid was a little high so I drained a little out. Thanks for your comments
