stupid mbc question
skills
Aug 28, 2004
palm springs, Washington
okay i just installed my mbc using these instructions http://dsmtuners.com/forums/showthread.php?t=105573 and first of all let me say i did read the entire thing and i do have common sense but i think i got confused. it says unplug the bcs or leave it plugged in and toss it to the side? well which one is it common sense tells me to disconnect it other wise the boost controller is useless. and secondly t2 source inlets to the factory bcs (from the ic piping and the factory 1g maf) are these the 2 source units is tells to plug up? again common sense tells me yes but i just want to make sure.
ryan
here is some plain dir...
there are 2 vac lines going to the turbo ur mbc goes to the wastegate and the other line u dissconect..the other line off ur mbc u tee in to ur bov
Jesse :talon:
okay like i said i installed it exactly how the diagram states. so what do i do about the line coming off the intake adn the line coming off the intercooler piping? just cap those 2 or what?
you could do that or u can just pool them off the factory solenoid...Those lines controlled the boost pressure ur completely replacing it w/ the mbc so it really doesn't matter what u do w/ those lines...but i would remove them incase they get cought on something in the engine...
