Strut Tower Caps
New2DSM_NY
May 25, 2011
Bath, New York
My strut tower is rotted on both sides and won't pass inspection here Upstate NY. I've seen strut tower caps for the older Dodge/Plymouth vans and wondered if either somebody makes a strut tower cap for the 2g Eclipse or if the ones for the older vans will work. Not even sure how much a body shop will fix it for. Looking for suggestions. Definitely a job I can't tackle. Thanks.
OK Thanks...I only saw the caps for older Dodge minivans. Don't know why they wouldnt make them for other vehicles...
Do you have any pics? I had the same problem on my 2g. The right side was rotted around the right edge of the strut tower. I know a very good welder and he cut all the bad metal out and replaced it with thick metal from a tool box. welded it in, seam sealer, bondo, paint. good as new!
