DSMDEMON93
- 319
- 2
- Feb 18, 2009
San Jose,
California
Hello everyone, so recently my front end was making a clunking noise. As it turns out, the Bolts that hold the Compression arm (Lower control arm that's curved) were backing out.
To make matters worse, the bolts I removed were unmatching. The thread size was a M12x1.75, which is way too coarse over the stock threads. I purchased the OE bolts that mount the compression arm, but the threads won't engage into the frame, since they have been deformed.
The only solution I can think of is the use of a Helicoil set, to set new threads for the bolt to bind to, BUT my question is....Will a helicoil kit withstand the punishment of suspension components? The twist/flex/pull motion the car takes on the road? I wouldn't want the kit to fail, causing the arm to fall off and send me into the wall.
Any inputs? Opinions? Suggestions? They are all appreciated. Thanks!
. Never had any luck with them if it were under a high clamping load. Give it a shot. But first I'd try cleaning up the threads like stated above. You'd be surprised how much it helps
