stock rebuild parts list
talontsi902
70
Nov 5, 2005
masillon, Ohio
ok i dont want to buy the top line kit. some thing i dont want to go cheap on so heres my parts list so fare im on a huge buget for this engine for the reson its not mine so its not my money heres what i got this is for a DD stock rebuil only wanting 350awhp with suporting mods
1g stock .20 pistons
Clevite Rod Bearing Set
Clevite Main Bearing Set
TopLine Water Pump
Balance Shaft Eliminator Kit
Topline Complete Engine Gasket Kit
arp Rod Bolts
arp Head Studs
1g big rods reusing my old ones
what am i missing im still not shure on head gasket any help would be great thanks guys
I would use 2g pistons but that just me. As for the headgasket I would go with a mitsu multi layer but make sure the head and blocked are decked first or it won't seal and you will have some problems. Sure you got this covered but don't forget to buy all new timing belt stuff(iddler pulley, new belt, and the tensioner tool if you don't have one).
yes we were going to go with 2g pistons but from what im reading it would turn into a pita to get them meachened and how much hp are the stock pistons good for ?
Same as the 1g 400-450ish but the 2g's have higher compression offering better off boost drivability(more torque) and better spool.
im still thinking about the 2g pistons then but am i missing anything form my list im building this from a bare block and using my crank and rods what more will i need thats not listed and i cant use from my old block ?
