stock oil guage reads above H?? What is wrong??
HotSauce GS N/T
170
Jan 29, 2004
Wilmington, North Carolina
Ever since I installed a fmic the stock oil guage has been rising past H when car in running. The only time the oil gauge reads in the "normal" range is when I first start the car. Then after a little while it wil pin past "H" What is going on here?? I did some research and someone mensioned to change the pcv valve??? What else could be the problem??
I will have to check the wire and sensor out. I did unplug the sensor by accident when installing the intercooler piping under the window wash container, so chances are the pipes couild be interfering with the wire again. Thanks defiant! who knew you could solve my problem AND save me money on a car rental when I book it with a hotel!!
