Stock O2 Housing and aftermarket downpipes?
Jezza
88
5
Feb 23, 2011
Appleton, Wisconsin
Does the 3" Megan Racing Downpipe bolt up to the stock O2 housing? I'd rather know that I need to buy a new O2 housing now instead of when I try to bolt up the new dp.
This is on a '97 TSi AWD
It bolts up. However, b/c the Megan dp is actually 3" at the end which is much larger then the stock 02 housing, you have to make sure you line everything up (gaskets, bolt holes etc) before you tighten everything down for good. I found that using RTV to hold the gaskets in place while I fumble with hardware works quite nicely.
Yes, exhaust pieces are almost always engineered around bolting to stock components on both ends.
Thanks alot for the quick responses guys. That's exactly what I (and my wallet) wanted to hear
