stock lines for 14b
Oil feed goes in through the top. Oil Drain comes out the bottom. These are the two easiest, as there is NO way you can get them confused.
As for the water lines, since they flow horizontally through the CHRA, I don't believe it matters which one is technically the "feed" and which is the "drain".
