2G Stock and aftermarket oil pressure gauge
ishnish
940
156
Jun 26, 2011
Modesto, California
Hey guys so I just got new gauges to fill out my pillar pod which fits 3 gauges. All of them are the Halo Prosport gauges. One is an oil pressure gauge. My question is if I'd be able to use both the stock oil pressure gauge and aftermarket oil pressure gauge at the same time. I don't like having anything in my car not work it would just make it look cheapy LOL hard to explain but it's just a problem I have with my car. So does anyone know if this could be done? I've searched around a bit but haven't found any direct answers on the subject.
Yes it can be done. I did it a year ago or so.
You will need an SS line to install where the factory sender is now. Then mount a T on the other end of the SS line and install both senders on the T. They are both 1/8in NPT IIRC, same as the hole you will be using for the SS line into the OFH.
Thanks for the reply. I saw this on there website and was wondering if it would be a good option:
Oil filter adaptor plate-Sandwich adaptor Plate -Prosport Gauges
What do you think?
