Stock 420a throttle body.
dj_lethrow
137
May 5, 2003
north dakota, North Dakota
I was wondering what the stock bore on the 420a throttle body is? I have a 95 talon esi. Reason for asking is a friend wants to know if it would fit on his 2000 neon. I have no clue if it would, but if anyone has any sort of imput that would be awesome. Also the neon is manual with cruise control.
48MM
Are you sure about that? I just put a vernier caliper to a spare TB I had laying around and I'm reading 51-52mm.
I too thought it was 52mm but am not sure
Well, the TB bore obviously tapers a bit, hence the range of measurements I posted. Near the entrance it's about 52mm, while closer to the butterfly, it's 51mm. In either case, 52mm should be the answer you're looking for.
The inlet is 52mm, then it narrows inwards to 48mm. then back 52mm right before the butterfly and after it also. I have bored a stock TB before so I can confirm. Also CI offers a straight 52mm bored which elimates the 48mm narrow section.
