420a throttle body leak
Take the TB apart and put a rubber o-ring around the shaft on the outside of the bearing. do it on both side of the shaft . I think i have pics of mine if I can find them ill post
^^^ This. Car will run so much better after you seal the shaft up. I know you can buy the o-rings at local hardware stores for cheap.
yes can you please post a pic up of how you did it
His car is speed density so a pre map leak won't effect performance.
exactly but I'm just trying to have everything perfect before i even drive it 4hrs away
These pics just show where to place the o-rings on the 420a TB. You need an 0-ring that fits around the outside of the shaft and place on the outside of bearing.
Try placing a very thin washer with the inside diameter the width of the shaft and put it over the o-ring then the spring/shaft over that. I forgot to mention I have a thin hard plastic washer on mine with the o-ring under it.
