stft ltft o2 trying to tune safc
joeyzaza
128
Jul 19, 2008
muskegon, Michigan
I'm trying to tune my car with a SAFC. I just put in a Walbro 190 and some RC 550 injectors. I have a FMIC and a 14b turbo, on my 2g gsx. I'm logging with Evo Scan.
I have searched and searched, but I think there is something wrong with my car. I have read that I should not look at o2 voltage unless i'm at WOT. I'm just trying to see some changes in my fuel maps at idle, but am not getting very good results. My STFT sits at around +5 no matter what I set the SAFC too. My LTFT stays at + 0.1008.
I'm really kind of lost on this, I set the SAFC at - 15% as base correction, I change the low throttle settings but the STFT stay the same.
Please help, i've read a ton on tuning.
Is the motor getting up to normal operating temperature? I believe it has to get above 186* before the fuel trims start to change.
That LTFT value makes me think there might be an issue with the EvoScan.
I have to reinstall office in order to post the log.
I have a question though, what should my o2 sensor voltage be reading while idling. It stays steady for awhile and sometimes drops to 0 and stays there for a few seconds. I thought it was supposed to be cycling while in the low fuel trims??
Here is a log, mostly idling, some driving around. I think the o2 sensor is bad, what do you guys think??
TPS RPM Timing FT LOW FT MID FT HIGH STFT O2 VOLTAGE
16.47058824 531.25 9 0.1008 0.1008 0.1008 0.1008 0.07808
16.47058824 593.75 8 0.1008 0.1008 0.1008 0.1008 0.0976
16.47058824 593.75 8 0.1008 0.1008 0.1008 0.1008 0.07808
16.47058824 562.5 8 0.1008 0.1008 0.1008 0.1008 0.07808
16.47058824 531.25 7 0.1008 0.1008 0.1008 0.1008 0.07808
16.47058824 562.5 7 0.1008 0.1008 0.1008 0.1008 0.07808
16.47058824 531.25 8 0.1008 0.1008 0.1008 0.1008 0.07808
16.47058824 593.75 7 0.1008 0.1008 0.1008 0.1008 0.07808
16.47058824 562.5 9 0.1008 0.1008 0.1008 0.1008 0.07808
16.47058824 625 7 0.1008 0.1008 0.1008 0.1008 0.07808
16.47058824 593.75 6 0.1008 0.1008 0.1008 0.1008 0.07808
16.47058824 500 7 0.1008 0.1008 0.1008 0.1008 0.07808
16.47058824 562.5 6 0.1008 0.1008 0.1008 0.1008 0.07808
16.47058824 625 6 0.1008 0.1008 0.1008 0.1008 0.07808
22.35294118 593.75 7 0.1008 0.1008 0.1008 0.1008 0.07808
31.76470588 593.75 14 0.1008 0.1008 0.1008 0.1008 0.07808
25.49019608 750 4 0.1008 0.1008 0.1008 0.1008 0.07808
17.25490196 1187.5 18 0.1008 0.1008 0.1008 0.1008 0.07808
17.25490196 1406.25 21 0.1008 0.1008 0.1008 0.1008 0.07808
17.25490196 1406.25 20 0.1008 0.1008 0.1008 0.1008 0.07808
18.03921569 1375 19 0.1008 0.1008 0.1008 0.1008 0.07808
21.56862745 1343.75 18 0.1008 0.1008 0.1008 0.1008 0.07808
21.56862745 1312.5 18 0.1008 0.1008 0.1008 0.1008 0.07808
17.64705882 1406.25 20 0.1008 0.1008 0.1008 0.1008 0.07808
18.03921569 1437.5 20 0.1008 0.1008 0.1008 0.1008 0.07808
32.54901961 1375 21 0.1008 0.1008 0.1008 0.1008 0.07808
19.21568627 1656.25 23 0.1008 0.1008 0.1008 0.1008 0.07808
17.25490196 1937.5 27 0.1008 0.1008 0.1008 0.1008 0.07808
17.25490196 1968.75 28 0.1008 0.1008 0.1008 0.2969 0.07808
17.25490196 1937.5 28 0.1008 0.1008 0.1008 0.6891 0.07808
17.25490196 1875 27 0.1008 0.1008 0.1008 1.0813 0.07808
20.39215686 1812.5 26 0.1008 0.1008 0.1008 1.4735 0.07808
24.31372549 1718.75 25 0.1008 0.1008 0.1008 1.8657 0.07808
21.17647059 1781.25 26 0.1008 0.1008 0.1008 2.2579 0.07808
17.64705882 1875 27 0.1008 0.1008 0.1008 2.6501 0.07808
17.64705882 1843.75 27 0.1008 0.1008 0.1008 3.0423 0.07808
17.64705882 1812.5 26 0.1008 0.1008 0.1008 3.4345 0.07808
17.64705882 1718.75 25 0.1008 0.1008 0.1008 3.6306 0.07808
17.64705882 1625 24 0.1008 0.1008 0.1008 4.0228 0.07808
17.64705882 1531.25 22 0.1008 0.1008 0.1008 4.2189 0.07808
17.64705882 1437.5 21 0.1008 0.1008 0.1008 4.6111 0.07808
17.64705882 1343.75 18 0.1008 0.1008 0.1008 4.8072 0.07808
17.64705882 1281.25 16 0.1008 0.1008 0.1008 5.0033 0.07808
17.64705882 1187.5 15 0.1008 0.1008 0.1008 5.1994 0.07808
17.64705882 1093.75 13 0.1008 0.1008 0.1008 5.3955 0.07808
17.64705882 1031.25 10 0.1008 0.1008 0.1008 5.5916 0.05856
17.64705882 937.5 9 0.1008 0.1008 0.1008 5.5916 0.05856
17.64705882 875 8 0.1008 0.1008 0.1008 5.7877 0.05856
17.64705882 812.5 6 0.1008 0.1008 0.1008 5.7877 0.05856
17.64705882 781.25 6 0.1008 0.1008 0.1008 5.9838 0.05856
17.64705882 750 5 0.1008 0.1008 0.1008 5.9838 0.05856
17.64705882 718.75 5 0.1008 0.1008 0.1008 6.1799 0.05856
17.64705882 687.5 6 0.1008 0.1008 0.1008 6.1799 0.05856
17.64705882 656.25 6 0.1008 0.1008 0.1008 6.1799 0.05856
17.64705882 687.5 7 0.1008 0.1008 0.1008 6.376 0.05856
17.64705882 718.75 7 0.1008 0.1008 0.1008 6.376 0.05856
17.64705882 750 7 0.1008 0.1008 0.1008 6.5721 0.05856
17.64705882 781.25 6 0.1008 0.1008 0.1008 6.5721 0.05856
17.64705882 781.25 7 0.1008 0.1008 0.1008 6.7682 0.05856
17.64705882 781.25 6 0.1008 0.1008 0.1008 6.7682 0.07808
17.64705882 781.25 6 0.1008 0.1008 0.1008 6.9643 0.07808
17.64705882 781.25 5 0.1008 0.1008 0.1008 6.9643 0.07808
17.64705882 750 5 0.1008 0.1008 0.1008 7.1604 0.07808
17.64705882 750 6 0.1008 0.1008 0.1008 7.1604 0.05856
17.64705882 718.75 6 0.1008 0.1008 0.1008 7.3565 0.07808
17.64705882 750 6 0.1008 0.1008 0.1008 7.3565 0.07808
17.64705882 718.75 6 0.1008 0.1008 0.1008 7.3565 0.05856
17.64705882 718.75 6 0.1008 0.1008 0.1008 7.5526 0.07808
17.64705882 718.75 6 0.1008 0.1008 0.1008 7.5526 0.05856
17.64705882 718.75 7 0.1008 0.1008 0.1008 7.7487 0.05856
17.64705882 718.75 7 0.1008 0.1008 0.1008 7.7487 0.07808
17.64705882 750 7 0.1008 0.1008 0.1008 7.9448 0.05856
17.64705882 750 6 0.1008 0.1008 0.1008 7.9448 0.05856
17.64705882 750 6 0.1008 0.1008 0.1008 8.1409 0.07808
17.64705882 750 6 0.1008 0.1008 0.1008 8.1409 0.05856
17.64705882 750 6 0.1008 0.1008 0.1008 8.337 0.07808
17.64705882 750 6 0.1008 0.1008 0.1008 8.337 0.05856
17.64705882 750 6 0.1008 0.1008 0.1008 8.5331 0.05856
17.25490196 750 6 0.1008 0.1008 0.1008 8.7292 0.05856
17.64705882 750 6 0.1008 0.1008 0.1008 8.7292 0.05856
17.25490196 750 5 0.1008 0.1008 0.1008 8.9253 0.05856
17.64705882 718.75 6 0.1008 0.1008 0.1008 8.9253 0.05856
17.64705882 718.75 6 0.1008 0.1008 0.1008 9.1214 0.05856
17.64705882 750 6 0.1008 0.1008 0.1008 9.1214 0.05856
17.64705882 750 6 0.1008 0.1008 0.1008 9.3175 0.05856
17.64705882 781.25 6 0.1008 0.1008 0.1008 9.3175 0.05856
17.64705882 781.25 5 0.1008 0.1008 0.1008 9.5136 0.05856
17.64705882 750 5 0.1008 0.1008 0.1008 9.7097 0.05856
17.64705882 750 6 0.1008 0.1008 0.1008 9.7097 0.05856
17.64705882 750 6 0.1008 0.1008 0.1008 9.9058 0.05856
17.64705882 750 5 0.1008 0.1008 0.1008 9.9058 0.05856
17.64705882 718.75 6 0.1008 0.1008 0.1008 10.1019 0.05856
17.64705882 750 6 0.1008 0.1008 0.1008 10.1019 0.05856
17.64705882 718.75 6 0.1008 0.1008 0.1008 10.298 0.05856
17.64705882 750 6 0.1008 0.1008 0.1008 10.298 0.05856
17.64705882 750 6 0.1008 0.1008 0.1008 10.4941 0.05856
17.64705882 750 6 0.1008 0.1008 0.1008 10.6902 0.05856
17.64705882 718.75 6 0.1008 0.1008 0.1008 10.8863 0.05856
17.64705882 750 6 0.1008 0.1008 0.1008 10.8863 0.05856
17.64705882 750 6 0.1008 0.1008 0.1008 11.0824 0.05856
17.64705882 750 6 0.1008 0.1008 0.1008 11.2785 0.05856
17.64705882 781.25 6 0.1008 0.1008 0.1008 11.4746 0.05856
17.64705882 781.25 7 0.1008 0.1008 0.1008 11.4746 0.05856
17.64705882 781.25 6 0.1008 0.1008 0.1008 11.6707 0.05856
17.64705882 750 5 0.1008 0.1008 0.1008 11.8668 0.05856
17.64705882 781.25 5 0.1008 0.1008 0.1008 11.8668 0.05856
17.64705882 781.25 5 0.1008 0.1008 0.1008 12.0629 0.05856
17.64705882 781.25 6 0.1008 0.1008 0.1008 12.259 0.05856
17.64705882 781.25 6 0.1008 0.1008 0.1008 12.4551 0.05856
17.64705882 781.25 5 0.1008 0.1008 0.1008 12.6512 0.05856
17.64705882 750 5 0.1008 0.1008 0.1008 12.6512 0.05856
17.64705882 750 5 0.1008 0.1008 0.1008 12.8473 0.05856
17.64705882 750 5 0.1008 0.1008 0.1008 13.0434 0.05856
17.64705882 750 6 0.1008 0.1008 0.1008 13.0434 0.05856
17.64705882 750 6 0.1008 0.1008 0.1008 13.2395 0.05856
17.64705882 750 6 0.1008 0.1008 0.1008 13.4356 0.05856
17.64705882 750 5 0.1008 0.1008 0.1008 13.6317 0.05856
17.64705882 781.25 6 0.1008 0.1008 0.1008 13.8278 0.05856
17.64705882 781.25 6 0.1008 0.1008 0.1008 14.0239 0.05856
17.64705882 812.5 6 0.1008 0.1008 0.1008 14.22 0.05856
17.64705882 812.5 6 0.1008 0.1008 0.1008 14.4161 0.05856
17.64705882 812.5 6 0.1008 0.1008 0.1008 14.6122 0.05856
17.64705882 812.5 6 0.1008 0.1008 0.1008 14.8083 0.05856
17.64705882 812.5 6 0.1008 0.1008 0.1008 15.0044 0.05856
17.64705882 812.5 6 0.1008 0.1008 0.1008 15.2005 0.05856
17.64705882 812.5 6 0.1008 0.1008 0.1008 15.3966 0.05856
17.64705882 781.25 6 0.1008 0.1008 0.1008 15.3966 0.05856
17.25490196 812.5 6 0.1008 0.1008 0.1008 15.5927 0.05856
17.64705882 812.5 6 0.1008 0.1008 0.1008 15.5927 0.05856
17.64705882 812.5 6 0.1008 0.1008 0.1008 15.7888 0.05856
17.64705882 812.5 6 0.1008 0.1008 0.1008 15.9849 0.05856
17.64705882 812.5 6 0.1008 0.1008 0.1008 16.181 0.05856
17.64705882 812.5 6 0.1008 0.1008 0.1008 16.3771 0.05856
17.64705882 812.5 6 0.1008 0.1008 0.1008 16.5732 0.05856
17.64705882 812.5 6 0.1008 0.1008 0.1008 16.7693 0.05856
17.64705882 781.25 6 0.1008 0.1008 0.1008 16.9654 0.05856
17.64705882 812.5 6 0.1008 0.1008 0.1008 16.9654 0.05856
17.64705882 843.75 6 0.1008 0.1008 0.1008 16.9654 0.05856
17.64705882 812.5 7 0.1008 0.1008 0.1008 16.9654 0.05856
17.64705882 843.75 7 0.1008 0.1008 0.1008 16.9654 0.05856
21.17647059 843.75 7 0.1008 0.1008 0.1008 16.9654 0.05856
26.2745098 812.5 13 0.1008 0.1008 0.1008 16.9654 0.05856
17.25490196 937.5 15 0.1008 0.1008 0.1008 16.9654 0.05856
17.25490196 1218.75 19 0.1008 0.1008 0.1008 16.9654 0.05856
17.25490196 1375 19 0.1008 0.1008 0.1008 16.9654 0.05856
17.25490196 1468.75 21 0.1008 0.1008 0.1008 16.9654 0.07808
17.25490196 1468.75 21 0.1008 0.1008 0.1008 16.9654 0.05856
17.25490196 1406.25 20 0.1008 0.1008 0.1008 16.9654 0.05856
17.25490196 1343.75 19 0.1008 0.1008 0.1008 16.9654 0.05856
17.25490196 1281.25 17 0.1008 0.1008 0.1008 16.9654 0.05856
17.25490196 1250 16 0.1008 0.1008 0.1008 16.9654 0.05856
17.25490196 1187.5 14 0.1008 0.1008 0.1008 16.9654 0.05856
17.25490196 1125 13 0.1008 0.1008 0.1008 16.9654 0.05856
17.25490196 1031.25 11 0.1008 0.1008 0.1008 16.9654 0.05856
17.25490196 968.75 10 0.1008 0.1008 0.1008 16.9654 0.05856
17.25490196 906.25 9 0.1008 0.1008 0.1008 16.9654 0.05856
17.25490196 843.75 8 0.1008 0.1008 0.1008 16.9654 0.05856
17.25490196 812.5 7 0.1008 0.1008 0.1008 16.9654 0.05856
17.25490196 812.5 6 0.1008 0.1008 0.1008 16.9654 0.05856
17.25490196 750 5 0.1008 0.1008 0.1008 16.9654 0.05856
17.25490196 750 5 0.1008 0.1008 0.1008 16.9654 0.03904
17.25490196 718.75 5 0.1008 0.1008 0.1008 16.9654 0.03904
17.25490196 718.75 5 0.1008 0.1008 0.1008 16.9654 0.05856
17.25490196 781.25 5 0.1008 0.1008 0.1008 16.9654 0.03904
17.25490196 750 6 0.1008 0.1008 0.1008 16.9654 0.03904
17.25490196 781.25 6 0.1008 0.1008 0.1008 16.9654 0.03904
17.25490196 812.5 6 0.1008 0.1008 0.1008 16.9654 0.03904
17.25490196 750 5 0.1008 0.1008 0.1008 16.9654 0.01952
UPDATE: I installed a new o2 sensor, and now the voltage moves around like it should. The old one rattled???
Anyways, I have begun setting up the SAFC, and I have to adjust it all over the place in order to get the STFT to zero, I have some RPMS negative, and some postitive, any insight on this??? I need a wideband!!!!
Well now the car is starting to get tuned. I have gotten 1000 2000 and 3000 set. My low ltft is now at almost 0 woot woot. I started to get it right the other day, and my alternator went out! These cars are expansive.
Wide band o2 is next on the mod list!
^ I am right their with ya. As soon as the money comes, WB02...and some other gauges. I hate not knowing!
