Steering wheel adapter hub
quicksilver
May 31, 2005
Poland, Ohio
I am looking for a steering wheel hub adapter, a few years ago I bought one for my 2k Avenger :laser: from "speedpeople" (out of buisness now) and it was a perfect fit :thumb: ...it actually fit the steering column plastic trim steering wheel hole diameter like it should, it is made of cast aluminum with a black wrinkle finish...on my invoice there is no mention of the manufacturer of this adapter,so....recently I bought another aftermarket steering wheel for my 96 2g Eclipse and can only find the current crop of Momo or Grant crappy ones with the rubber accordian slip cover , I bought one and it looks like arse :notgood: leaving almost a 1/2" of open gap at the column plastic trim opening(opening where clockspring used to be). If you know where I can find one of the black wrinkle finish cast aluminun correct fit ones I would greatly appreciate it.
did you try summit racing or Jeg's? If not there, then check ebay - usually good stuff there
Yep both bought a grant adapter from Summit and the Momo one off ebay..thanks
