Starter Won't Crank After AT->5spd Swap
Mr96GSX408
417
3
Jul 14, 2002
Bay Area/Central Coast, California
I just finished an automatic to manual transmission swap and I'm having trouble getting the starter to crank.
Here are the steps that I have performed:
- I have soldered leads (5) and (8) together from the A101 plug, as well as the various combinations to achieve PARK or NEUTRAL as shown below:
Not mine, but from a fellow forum member:
- I have disconnected all the plugs running to the factory TCU and have removed the TCU.
- I have made sure that the starter is properly grounded to the transmission by grounding the ground wire located on the harness. The ground wire is now bolted onto the transmission; this bolt also bolts the starter to the transmission.
- I have made sure that the 2 wires (S) and (B) are properly connected to the starter, as shown below:
- I have checked that the starter works by hooking the terminals of the starter up to jumper cable leads and to a battery.
- I have made sure that the stock wiring harness of the AT was not damaged during the transmission swap.
- I have wired the reverse light up by splicing and soldering the (7) and (8) leads (A101 plug) up to a donor reverse light plug off of a manual transmission car.
- My MFI system works, as when I turn to "START" my fuel pump whirrs and my injectors spray.
- I have checked my MOTOR fuse under the hood, no fuses blown.
- My battery is full, as I have a charging system and an external rechargeble jumper battery.
Below are some diagrams that I have used in my effort to solve this problem. Copy/Paste as the diagrams are quite large.
http://img300.imageshack.us/img300/5417/107gz4.jpg
http://img300.imageshack.us/img300/9016/195hc5.jpg
I at my wits' end and am out of ideas, as my car started perfectly everytime prior to my 5-speed swap. If anybody has any insight and would like to share your thoughts, I would greatly appreciate it.
An update to my problem:
Its fixed. My diagnosis was right, the wire running from the starter relay to the starter solenoid did not have proper continuity. After that was fixed, the car started up fine.
Thanks for everyone who had an input.
