starter positive terminal?
kneipperk
214
Oct 25, 2009
aurora, Colorado
I just wanted to make sure before i hook everything up tomorrow and try to start the car... is this the positive terminal on my starter?
I have the negative grounded to my transmission/starter bolt. And the small wire hooked to the middle of the starter
I am preaty sure it is.Hook up some jumper cables to your battery ground the starter and tap it with the positive its a good way to make sure it will work after you install it.
as said before. it goes on he other on. that has the power, the plat plug is for the solenoid that turns the starter motor on. the one with the arrow is wired to the starter motor. i found this out the hard way.
