stalling almost dies on take off
docb002000
204
May 21, 2010
Phenix City, Alabama
:confused::mad:As I go to take off from a stop I give the car gas to go it feels like it bogs and stalls then BAM 15psi, it kinda bucks a little bit then it goes. I did a blt fixed them and still does it. My set up is t25, smic, hard pipe kit, hks bov (recir), mbc hooked to wg and port on turbo housing, egr block off. what am I doing wrong? Oh and my walbro (190 re-wired) goes from quiet at idle to screaming while trying to drive until i shut off the car.
Try resetting the ECU and see if it still acts the same afterwards.
Unplug the battery :thumb: It will clear out fuel trims and timing pull as well as any CELs. You don't have any CELs do you?
Oh LOL if thats the case it gets reset everytime I pull back in to the garage since I cant get it further than a mile down the road. I was wondering if a clogged fuel filter could cause this I am have fighting this for awhile everything was replaced either before or during the rebuild. which was a one year gap.
the car just stalls on take off like lag then hang on shouldnt it be a gradual climb?
sorry to cel.....
CEL = Check Engine Light.
If the fuel filter hasn't been replaced, that could add to your problems as well
I did the erg delete per the diagram I found on here when I was putting my motor in. Doing this which had me run the fpr to the im............do I need the fps hooked back up if I am not running any other fuel management other than the stock fpr?
