SSAC FMIC Blow thru setup
JDR7919
301
Jan 1, 2005
Titusville, Florida
Has anyone used the ssac kit in blowthru? How did you modify the upper pipe?
Thanks how much did you have to cut off? Where did you get the couplers do you know the size?
Just cut the throttle body elbow pipe. Measure 5 times and cut once.
The couplers are 2.5" to either 3" or 3.5" depending on the GM maf you decide to go with.
We've had to install this setup a couple times to accommodate the GM maf and it's incredibly easy. Just make sure you create some sort of bead on the TB elbow before you get it all back together :thumb:
What did you do to make the bead on the pipe?
    • dsmmario
    • Detail
    • dsmmario
    • Canadian_CD9A
