SS oil line rerun
andytalon
277
7
Mar 27, 2005
Boston, Massachusetts
I was wondering I saw a kit that runs the oil line on a 1g to the oil filter housing, to get first priorty oil right after the filter, anyway I just recently got the line that goes from the turbo to the head, put the banjo bolts on and i noticed after 2 days there was a lil drop of oil on the head part, so I tightend it and the bolt broke the head. I got some Jb weld, and poped some in there, and I was gunna drill it and rethread it but, cant I just block it off and run that same fitting to the oil filter housing? All I would need to know is where to mount it and what hardwhere(fittings) I would need for this line (http://www.slowboyracing.com/more.php?id=2355&)
I have the turbo banjo bolt I would just need the fittings for the filter housing thats it, Anyone help would be greatly apprechiated!!
-andy
Spell check doesn't work??????:sosad: :sosad:
Ask SBR, but it should come with the required installation equipment. Atleast the one I got from RRE did. The banjo bolt will only be used at the turbo connection. Seal off the head oil feed area. Pull off the block-off bolt at the oil filter housing (assuming it's near the same as 2G's). Then thread the new oil feed line on with the proper fittings. My kit came with 1 90* angeled adapter one for the oil filter housing.
well the problem is I have the kit for Turbo-Head, not the one that you are talking about, I was going to convert mine to the one you have, what would I need to do that with the line I have?
First off, you will need a longer line because the one you have is too short. You will need a 3/8 npt to 1/8 npt reducer to screw into the oil filter housing, a 1/8 npt to -3 or -4 an(depending on what size line you have) and I would suggest that be a 45* fitting for best clearance.
You would be better off just buying the line kit for the oil filter housing.
