Spyder Electrical Issues
tylerbelcher
Dec 1, 2008
West Olive, Michigan
The car -
1996 Spyder GS 4G64
Automatic
The problem -
Headlights stay on even when switch is off. No climate controls, no stereo power, no interior lighting. Horn was blaring until I took it out.
The car was purchased with a cheap aftermarket remote start system in place, which I have removed since the problems started. No help there.
Any ideas? They problems seem unrelated. I have a good bit of wiring knowledge but I have not owned a 2G before. I had a 1G Eclipse (1.8L) a while back, but none of the electrical problems.
sounds like one of your relays are stuck "open" try swapping out one relay * for the other until you find out which one is the culprit. also a simple job finding an open in your electrical system would help you find any problems too.
