91Bomb
- 908
- 7
- Jul 15, 2003
US,
New Jersey
I spun a rod bearing and found quite a bit of metal flakes in oil pan even though bearing appears 99% intact. Oil looks clean so I'm not sure if metal flakes in pan are from car being 24 yrs old with 200k mi or from this bearing. Do the flakes in oil pan tell me everything I need to know on whether parts like oil pump need to be replaced now or should I cut open oil filter too and make a judgement afterwards?
Assuming what I found already in oil pan is a big enough concern, what should be replaced or cleaned thoroughly on a rebuild? I just seen a thread saying replace oil pump, oil cooler, + lines. How do i clean the turbo and cylinder head out? Can the oil pick-up tube be cleaned? What else needs to be done?
