Sprint Front Camber Kit Confusion
tighty
157
Nov 23, 2004
Sacramento, California
Hey everyone, I just installed a Sprint Front Camber kit for my car. It is the offset bushing style I believe. They look like this.
<img src="http://www.sprintspring.com/images/CAMBER.jpg">
The other side has a hex head on it to use to adjust them. In the instructions, which were worded rather wierdly, so I may have misinterpreted, it says that the the hex heads should be "pointing towards each other on the inside of the upper control arm." This is the way I have them installed but it seems like its kind of hard to get in there and adjust them. I also read in a vfaq where they installed offset bushings into stock arnchor bolts that they said the hex heads should be pointing toward the outside. Anyone have any experience with these and if they are actually supposed to point toward the inside, or if it even matters? I would rather have them point away from each other toward the outside so I could actually adjust them =).
Thanks in advance.
So no one else has this kit or has installed the offset bushings before? Please help folks as I want to make sure its right before I put the wheels back on and take it to get it aligned.
Thanks.
