Front camber kit.. grease?
Fmstrat
90
Jan 17, 2003
Apex, North Carolina
I got a polyurathane bushing type front camber kit for my 2G from DSM Trader. It did not include the grease that they say to use. What kind of grease should I be using? Also, how should the grease be applied? To the metal insert or to the outside of the bushing, or both?
Thanks.
I'm still waiting on my camber kit...
The ES poly master kit had silicone grease. I would grease both sides. The poly to prevent squeeks and wear and the metal to prevent galling and seizing in place should you ever want to remove it.
Just get the grease from somplace that sells the polybushings or use a similar grease if you can find one. A molybased grease should be ok but probably will need to be relubed before something greased with the bushing MFG's specified lube. It really feels like someone mixed wet silicone sealant with moly lube.. It is kind funky and a bi*** to get off your hands.
