spray paint on accident on car, will it buff out?
realitytb
197
May 19, 2004
idaho falls, Idaho
i got a little bit of spray paint on my car!!!!!! Will this stuff buff out? what can i do??? help!
theres this stuff called goof off, put it on a rag and rub the paint off. I used it to remove paint from the side of a car after they painted the yellow lines on the roadway.
Depends on what kind of paint and whether it hit your paint or just your wax. Go easy on trying to get it off, and do it really soon. I'd try using your regular wax, first.
goto walmart and get this stuff called OOP'S its in a white can and works great
I would try the clay bar first. If your wax job caught it that should fix you up. Otherwise goof-off or Oops! should do the trick. If you see the color of your car coming off on the rag stop.
thanks for all of the help! i got some meguairs cleaner compound and it buffed right out! then i waxed it, and it looks just as good as it did before!
Wax as the car apology, like a bouquet of flowers to the woman! I'm glad to know I'm not the only one!
