Speaker problem
PowerThrash
Oct 9, 2007
Indianapolis, Indiana
Alright I had to replace my shift cables after I broke the old ones. After everything was back together my head unit would work but there is no noise coming from the speakers. I checked all of the wires for the head unit and the amp but still i am not coming sound. The radio works and the cds play but not sound:cry:
Did you check your fuses?
Did you by chance unplug the amp?
are you sure the volume is turned up :D
I unpluged everything and repluged them back in and I know the volume is up. I guess I need to check my fuses though, which ones should I check
  • Wanted 6 bolt NT water pipe
    • chrisman287
