Spark Plugs !! ASAP
alexrc
62
Sep 23, 2007
Santo Domingo, Central America
Hey got a question the spark plugs of my 420a are getting residues of oil or fumes , these are brand new spark plugs and after a while the car starts failing or going in 3 pistons , if you clean the spark plugs will go good, I have a msd coil pack and msd cables . any ideas ?
:dsm::rocks:
piston ring ? or oil valve ? the oil seal on the head are new
What do the plugs look like? You could have bad piston rings, valvestem seals, head gasket, and a number of other things. One thing for sure is that the MSD coil packs are known to fail and cause problems on the 420a platform. Whats your compression numbers across the board? should be around 180 if your stock, car is warm and throttle body at WOT.
ok i have a new head gasket i installed yesterday , and new , oil seal , i can get you the compression numbers the spark plugs are just a little like with fumes of oil not to much and i installed the new coil yesterday as well
well the car is not smoking , even at high revs . thats why i dont know what else to check , becouse the valve seals are new
well the car is not smoking , even at high revs . thats why i dont know what else to check , becouse the valve seals are new :barf:
