spark plug clarification
xM3RKNUx
33
Dec 7, 2008
ROCKVILLE, Maryland
i am new to dsm's and i had to change the head gasket ### i blew it and when i took the spark plugs off i didnt pay attention to were they go and we all know they arent like most cars so i put evrything back together and fired it up and it does idle by itself i dont know if its ### the timing is off or if the spark plugs are i the wrong sequence could anybody help me clarify this
the firing order on the coil pack is 4123 4 beeing at the far left hand side. and cylender number 1 is the cylender closest to the timing belt. when you took the belt off did you make shure the balance shafts were aligned properly. there is a blot on the back of the block that you have to remove and carfully put a screwdriver in to keep the shaft flat on the top. i have been working on these cars expesially the 1g eclipse seence i was 8 years old and my nick name is the walking chiltons. any questions just m me and ill get back to you asap.
  • Wanted 6 bolt NT water pipe
    • chrisman287
