1G sound system
norcal_drifter
486
Jun 10, 2010
San Jose, California
i have a 10" mtx terminator (TN10-04) sub in a truck slim box and a bridged renegade amp pushing it (REN550s) i was just wondering how i can get a little more bass for my setup or what i should switch out or any ideas. i went with this setup because i got it from the brother everything was brand new and i gave him 40 bucks and some stuff and my gsx has almost no room in the hatch, anyways i would really appreciate some help or tips, thank you very much
(car info. pinoeer deck, 4 way speakers all the way around (6x9 rear,5 1/2 doors,4" dash, tweeters), 1000w 4 channel amp, 30 amp fuse, 8 awg wire all around.)
amp info:
2-channel Car Amplifier
2 x 75 Watts RMS into 4 Ohms
2 x 135 Watts RMS into 2 Ohms
2 x 150 Watts Max into 4 Ohms
2 x 275 Watts Max into 2 Ohms
2 Ohm Stable
Mono bridgeable
MOSFET Power Supply
Tri-Mode Operation
High level Inputs
RCA Input and Outputs
High pass filter: 80 - 2000 Hz
Low pass filter: 50 - 250 Hz
Bass Boost Switch: 0,6,12 db
Dimensions: 10.04"W x 9.06"H x 2.17"D
sub info:
ALDS Asymmetrical Linear Drive System with a flat progressive spider and extended pole piece for smooth, linear, piston like drive
Exclusive Spider Plateau Venting cooling system cools at the voice coil
Rubber surround for greater durability and longetivity of the sub.
Specifications:
Part Number: TN10-04
Impedance: 4O
Frequency Response: 29Hz - 160Hz
RMS Power (Watts): 150
Recommended Amp Power (RMS): 75 - 150
Peak Power (Watts): 300
Sensitivity: 84.9dB (1W/1M)
Voice Coil: 1.50" (3.81 cm)
Magnet Weight: 27 oz.
Mounting Depth: 4.86" (12.35 cm)
Cut Out Diameter: 9.19" (23.33 cm)
Sealed Enclosure Net Volume: 0.75 ft³
Vented Enclosure Net Volume: 1.45 ft³
Volume Displacement (in³): 21.21
thanks again :hellyeah:
If it's currently in a sealed enclosure, swap it out for a vented one as that will give you more low end response. Also placement plays a big roll in output of the sub. Facing it towards the rear of the car usually yields the best results. you can also try stuffing the box with pollyfill to make the box sound bigger than it actually is. To be honest, don't expect too much from the terminator series as they are not MTX's best line to say the least.
Awesome, glad it worked out for you :rocks:... i need to start working on my system one of these days, LOL. take care:cool:
