sorry for this newb question
CABLODSM
98
Nov 4, 2014
joliet, Illinois
been searching online for a aluminum intake piping kit to replace the plastic one that my 96 gst has. the pipe the bov is connected to???
i found one on cx racing but it says its for the t25 only??
not sure why that would because the intake side doesnt connect to the turbo.. but to my FMIC>
my Fmic piping is bigger than the stock plastic pipe..
You looking for intercooler piping? Or intake for the turbo side.
Sounds like you are looking for the upper intercooler pipe. Search for "hard upper ic pipe". If you've been searching "intake" that's why it's saying for t25.
That is just ebay marketing over half the time they don't even know what they are selling sounds like you want new upper intercooler piping correct?
Yes my upper intercooler piping from the throttle body to the left side of the fuse box that connects to the fmic..[DOUBLEPOST=1416104672][/DOUBLEPOST]Yes I have the full fmic piping but I don't have a pipe to connect to my j pipe yet or the pipe to replace the plastic upper intake wich is what I want to buy
Wait a minute you just said you have the full fmic piping and then you say you don't have the upper nor the lower piping? so what are you trying to build your own piping im lost now
Sorry I ment I have the fmic and the piping that go with it..
only came with piping to get close to the turbo and enough to get close to the upper area.. u know the whole behind the left headlight.
I need a aluminium piping to replace the upper intake.. tthepipe where the bov sits on
Yea sorry I'm an hour away from the car but..
best way to explain it wich someone already did
it's the upper hard piping
Basically the pipe from the throttle body that extends down and to the side of the car. The pipe your blow off valve sits on..
The stock one is plastic on a gst.. I just want a aluminium upper intake pipe .
Ok well what you are meaning to say is that you don't have all of the fmic piping and you need the upper ic piping. Like I said before it just depends on how much you have to spend and the quality that you want
Yea just looking for something cheap. It's just aluminium piping
so you are having a FMIC, but trying to find a pipe go with the BOV to TB.
I guess this will need some custom fix to fit.
scfaust was in the same boat, he has an fmic kit, but from turbo to stock IC location, on his 2g. Sounds like CABLO looking for just the hard upper intercooler pipe, or uicp. you can probably google "2g uicp" and find lots of things for sale.
http://store.max-redline.com/servlet/-strse-976/Detail
This is what I need.. but the description says it won't fit a tdo5h[DOUBLEPOST=1416110379][/DOUBLEPOST]
Your exactly correct
I have the j pipe already.. I bought a big16g ported .. from cxracing.
Knock off but will get the job done I already have it installed as well as the Godspeed fmic.. just need a upper intake pipe to get her started.
My intercooler piping is bigger than the stock upper intercooler piping so yea won't hook up
The whole kit link you posted would probably work for him. But the second link is just like the kit he already found. I know it says on the link you posted its for a 16g or 20g but according to the pics it has it has the s pipe for the stock t25. If I'm not mistaken he has a td05 so he needs the kit with the j pipe and L pipe.
I stand corrected. If you already have the the turbo piped to the intercooler then get the cheaper kit that you found on max redline and just not use the s pipe. The upper pipes are the same it's the lower pipes that are different.[DOUBLEPOST=1416111708][/DOUBLEPOST]Ha he beat me to it
