sony xplod problems
miller97tsi
221
Jan 5, 2008
jacksonville, Florida
i have just installed this cd player it is used got it from someone i know. not that it matters. but i wired this thing up correctly and and i have no sound i have power and everything just no sound i even have static in the back ground. it shuffles through stations accepts cd the works. with this wired up correctly is there anything else that i can check. i did check the fuse on the back still good. only one wire that i did not hook up was the illum wire didnt think i need it doesnt involve sound. hopefully you can help.
i do have the stck amp i believe it is the infinity. is there a way to bypass this or make it work with my headunit. or do i need to remove the amp?
  • For sale 2g 2GB CAS Assembly ( Complete )
    2GB CAS Assembly ( Complete ) $85 + shipping and paypal feesYou must be registered to see element.
  • For sale 2g 2G Clock Spring, Wiper Stalk, Turn Signal Stalk
    2G Clock Spring, Wiper Stalk, Turn Signal Stalk $35 + shipping and paypal fees* removed from...
  • For sale 4G63 2G Cylinder Head
    2G Cylinder Head $250 + shipping and paypal feesYou must be registered to see element.You must...
  • Free 4G63 1G /2G ECU Connector
    Came with a parts car, 1GA Talon with a 2G ECU. Some wires look cut and spliced. I have no use...
    • Badge023
  • For sale 1g 1G Turbo Intake Kit
    Used 1G turbo intake kit. Fits on stock intercooler and uses stock BOV. Comes with the MAF and...
    • Badge023
