Someone Please Help Me Fast!!!!!!!!!!!
mattspyder
1,046
Nov 2, 2004
del taco, Wisconsin
hey my speaking buzz with my engine idol. if i step on the gas alittle the speaker sound will buzz like alittle whinning noise. its anoying as hell. anyone know what to do. i have a alpine cd deck and a seperate eclipse dvd player hooked up to a 400 watt amp. some please help!!!!!!!!
signal noise from your engine...they make kits that you hook onto the power line that will filter the signal out...go to your local audio shop and tell them you have signal noise and they will hook you up
I had a similar problem. Only my spekers buzzed, and it got louder when i turned my lights on. It was just a bad ground. I would check that first.
if your amp is in the trunk, make sure your rca wires aren't run to the back next to your power wire - run them back on opposite sides of the car
Good Engrish!
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
