Someone Please Answer This ? Want My Car Fixed
CRAIG___
54
Apr 22, 2008
KING, North Carolina
Hey Everyone Im New Here I Know A Little About Dsms But Not Much I Have A 93 Eagle Talon Tsi Fwd I Sent It Off To Get A Axle Put In It The Guy Kept It For A Week Said He Couldnt Get The Right Axle He Didnt Know If It Had A Motor Swap Or What Well Yes It Does I Forgot All About Telling Him It Has A 6 Bolt Motor Swap Can Someone Tell Me What Year The 6 Bolt Came It Tell Me What Year Axle I Need To Get So It Will Fit Thanks Alot
If he cant jack a car up, take a wheel off, pop the ball joint and pull the axle then he should not be touching a car.
The trans should be the same, and the axles are probly the same spline count. Get your car back and take it somewhere else.
6 bolt stopped in mid 1992.
6 bolt and 7 bolt has nothing to do with the axles has the only differences are the crank. Not the trans.
To bad your not closer id do fix it.
BTW auto or stick?
HE SAID HE TRIED 6 DIFF AXLES NONE WORKED IS TI HARD TO CHANGE THE AXLE THINK IM GONNA TRY TO DO IT
BTW auto or stick?
ITS 5 SPEED
Easy figure out what year your trans and etc is order axle and have it swapped or if not call guy who had car before you and/or shop that swapped out you motor and have them help you find the right axle.
the guy a bought teh car form wont answer my phone calls its just a axle not like im mad at him i just want it fixed anyway to tell on the motor ? i was thinking bout gettin a axle for a 91 since it came with a 6 bolt and trying it
