Soft clutch on start up
Wigley
31
May 20, 2014
San Antonio, Texas
The clutch is soft on start up but once warm it is back to right hieght and stiff again.
Here, fix you OE one.
http://www.summitracing.com/parts/d...stxh3Y2PWVcQmyxnDfSXiujBeFGgre9TwYaAvkd8P8HAQ
DISASSEMBLY
Follow disassembly steps outlined in illustration.
INSPECTION:
1. Check the inside cylinder body for rust or scars.
2. Check the piston cup for wear or deformation.
3. Check the piston for rust or scars.
4. Check the clutch pipe connection for clogging.
ASSEMBLY
Assembly in reverse order as Disassembly.
NOTE: Installation service points as follows:
A. Push rod assembly installation. (2)
NOTE: Set the length of the push rod assembly to the shown dimension to make the adjustment of the clutch pedal easier.
No. Warranty it out till you get a good one if all other bleeding/testing fails. But if you switch out 5 with the same issue, then yes.
Was this a problem before installing the new master cylinder?
I had the same situation before, services changed a new MC for me.
problem solved.
No it just started happening[DOUBLEPOST=1415462401][/DOUBLEPOST]Checked and it's seeping at the master cylinder on the push rod.
