SoCal DSM Meet February 25th!!!
Status
Not open for further replies.
SHE LIVES!!! after a grueling 24.5 hours of working open heart surgery on my anne with surge, she lives! MUAHAHAHAHAHA.....td-06 20g....750 injectors, fresh head....its all GEE DOUBLE O DEE GOOD!
One problem....the effin inlet of the oil feed line spits oil....does anyone know if a 20g has a different size inlet for the oil feed line? other than that...get rdy for some auto action!
Not to be stupidly obvious, but did you remember the copper washers on the fitting bolt? I left them off when I hooked up the 16G, and got oil everywhere.
i got a slight problem i need a new head gasket. i have a cometic one in my trunk fresh in plastic. what else would i need to do this job? i had a B$@%@ with the Grade over here in Camarillo. i was almost at over heat status. not good.
it took me and surge about 26 hours total to finish the swap of my head...
off the top I can think of you'll need:
mechanics tool set, mainly a breaker bar, palm size wratchet, flex extensions, a 10mm, 11mm, 12mm, 14mm, 17mm, 19mm, 22mm, heavy duty wratchet, 4 jack stands, a jack, 5 qts of oil, new oil filter, new belts, new head gasket, intake manifold gasket, exhaust housing gasket, thermostat gaskets, coolant, new head studs, tire iron, flat head screwdriver, pry bar or something to detach the head from the gasket and intake because its a PITA, new spark wires, plugs....
To do a head gasket swap you are pretty much removing the whole damn motor...
So expect to spend about $260 in just parts, and I hope you have plenty of FU**'s, DAMN's, SH1T's, punches, kicks, cuts, or any bodily damage available...:D
i say only about 32 or less go, knowing DSM they start to break the week before or on the week of these meets ROFL
well i put my request in .. i hope i get the day off..:thumb:
What time are you guys goin' to the Krispy Kreme?
i am Thinking 12 we leave so everyone be there at 11:30, If anybody is Hispanic be there at 10-9:30ish ROFL
:toobad: LOL We're supposed to be at Autobacs at 12, so shoot to arrive at KK around 10:30-11:00 so we can hang out a little, then leave around 11:30ish. :thumb:
ill be there iam going to have my super cool new turbo setup ready by then and i ordered a new roll cage from dsmparts.com its going to be a spectacular time.
I am still not sure If I am going or not. I can't believe none of you are going to Famoso on Saturday. It's Test and tune day, all day you can race for $30. I am going to finally see how my beast does.
man mike ill tell you how it runs. bwuhahaha arnt you running the t25? i plan on going and i need a new head gasket.
A flat, smooth, perfectly straight 1/4 stretch of road. How boring. ROFL Time for some DSMers to go to Streets of Willow. :thumb: Let us know how it goes if you do go. :dsm:
eclipsegsx1736 said:
A flat, smooth, perfectly straight 1/4 stretch of road. How boring. ROFL ...
Plus a 2 1/2 hour drive just to get there..
Its more accurate the GTECH!!! :p
:D
I will keep you posted....Who knows, I might actually be able to post pone this trip to the track so I can roll out there!
Well driving to this meet would be like a 4-5 hour drive!:D
Im that dedicated though.:sneaky:
you can stay at my house mike. wink wink. seriosly though if you need to.
I can't wait. From the list, i only see mine and maybe one other 1G? Where's all the 1G love? Oh well, it will be fun no matter what.
Status
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G ECM Link Speed Density Harness
    NEW 1G ECM Link Speed Density Harness $45 + shipping & paypal fees* these are $65 online * I...
