so now what to do?
talons95
Aug 2, 2003
omaha, Nebraska
(car= 95 talon nt) So i went to check up on my car .Had a brand new head put on because it was cracked. Everything is put back together but the damn thing is stalling like a mofo.It sounds like I just put in an aggresive ass set of cams. So i drive it around a couple blocks, and the damn thing dies at every stop, actually everytime i left off the gas. the mechanic said the computer was reading that the timing belt was off more then 1 or more teeth.so he redid the timing belt and same thing. So now it might be the cam angle sensor.What the hell the idle was fine before even with a cracked head.Is there any thing else that it could be or to look for .
are you running really rich? if so you prob have what im having LOL i cant tell you how to fix it but if you do lemme know k? :thumb: arent dsm's fun! :p
Check to make sure the timing belt was installed correctly. It sounds like the cams are off by a tooth, most likely it's the exhaust cam.
