SmartFire Injecors (SFI)
DO NOT BUY SFI INJECTORS!!!
well here i'm going to express my feelings for SFI Injectors. after 1000 miles, one stuck open and flooded one of my cylinders with gas, washing out the oil for the rings & causing oil starvation of the piston rings in that cylinder. my car ended up having compression check of: 185, 180, 150, 195. take a guess at which cylinder flooded. thanks SFI! now i have to rebuild my motor. atleast theres a full refund from the 1 year unlimited mile warranty. the ONE good thing SFI has is customer support for refunds and replacements.
to make sure, i pulled out the injector for the failed cylinder, blew out the gas, and tried to blow through it. the result was after any pressure was applied, the pintle leaked. so the injector was for sure the cause of the piston failure.
for the first 1000 miles, they worked just fine, ran like a stock car minus the 2000rpm idle, which might not be the injectors. i had the 660cc size.
  • Wanted 1g 6 bolt rear timing cover tins both sides.
    6 boltRear timing cover tins.
    • Robert503
  • For sale 1g 92-94 Mitsubishi tail lights
    These were take offs from a new GST on a road race team. I had got boxes of parts leftover...
  • Wanted 2g WTB: 2G Eclipse GSX / Talon TSi AWD (1995-1999)
    Looking to buy a 1995-99 AWD Eclipse GSX or Talon TSi — running or project, rust-free bones...
    • Total Eclips3
  • For sale Wideband
    • Briant91
  • Wanted 560 injectors
    • AllanL
