1G Slight power sputter
enriquez2000
2,411
1,020
Oct 5, 2014
fort collins, Colorado
Heres the symptom... car drives fine and pulls hard. When i am idling there is a sputter/misfire every so often. Its not consistent and usually will happen right after breaking at a light one time then go away.
Logic tells me spark.. i am not leaning or richening during the event. Changed plugs with no help. Ngk wires are not too old and coils ohm out at the top of spec(would like to see them at the bottom)
Fuel pressure on the gauge seems to be fine when it sits and idles during the event.
So i am keaning towards power transistor but want a sanity check before i drop money on a new one.
This makes me think that its IAC related. Have you tested / calibrated the IAC or cleaned it lately?
No.. i did replace it with a used one a while back.. i can ohm it out again. Last time it failed it got stuck at like 60 on link and stumbled hard and almost stalling. Ill ohm test it in the morning.. maybe its just on its way out
It is possible. Always best to check the obvious first.
  • Wanted 6 bolt NT water pipe
    • chrisman287
