Slight oil leak pooling at bottom of lower timing cover
bsbllfit7
1,104
3
Feb 17, 2009
Salem, Oregon
as the title states i have a slight oil leak that is pooling at the bottom of the lower timing cover. If i clean the area with the engine off it wont leak anymore. If its still clean and i just start the car up to see where its leaking from it wont leak. When i go on longer drives or probably get into boost it begins to leak. There is no traces of oil on the timing belt whatsoever and its literally pooling and dripping off of the lower timing cover. I tried searching for people with similar problems but it didnt seem like any had the same issues i had. Im probably going to have to pull the lower cover but want to know in advance if anyone has had any experience with this. The weird thing is that the timing belt isnt getting oil on it whatsoever. Any help is greatly appreciated!
Thanks in advance!
Could be so many things... front case not sealing? cam seals? valve cover gasket?
I would remove all 3 timing belt covers and try to find where the leak comes from w/ a bright light. You'll likely see a trail from the leakage point.
Yes there are small drips from the cover but no spray on the inner wheel. Anyone have a link to a post for removal of the timing covers. And also valve cover and cam seals are in perfect condition no leakage up top.
Sent from my HTC EVO 4G
Don't remember exactly but to remove the lower you need to remove all the pulleys.
Then its just a matter of removing the small bolts evrywhere.
As for upper and middle you just need to remove the bolts around it.
Be careful with the middle one: its fragile in the center section.
I removed mine without a puller, I say leave the tbelt on if you can so as not to mess timing.
Just remove the ps belt, ac belt, and waterpump belt iirc, remove the pulleys and your free to unbolt the lower cover.
I had a similar issue and after changing all gaskets, I found it was a o-ring in the oil pump. You might want to check there as well.
im thinking its going to be either a small gasket or the old BS pulley bolt (or was it the tensioner?). I know this can leak oil if you dont put rtv or thread locker on it and i honestly dont remember having that done.
That bolt for the BS tensioner could verylikely be the culprit. I put thread locker on the threads and some blue high temp RTV on the flat part that comes in contact with the frontcase. No leaks what so ever and def wont come out. Could also be a leaky OFH gasket, I would take off the lower timing cover and I bet you find the culprit there.
I had oil that would collect at the bottom near the oil filter housing and oil pressure sending unit. It turned out to be the power steering high pressure hose. It would leak on the power steering pump and all the way down. I'm not saying this is your issue, but something to think about if you dont see any oil after removing the timing cover.
Im having the same problem with my car. Im putting a quart of oil every week. Everything on the driver side of the engine is all full of oil.
Thats not bad. A guy I know in town went through 1 1/2 gallons the other day. He had oil all over the driver side and come to find out it was an oil cooler line.
took the cover off today and re tightened everything down there. Once i got it all tightened and cleaned up i put the crank pulley back on and left the cover off. I started her up and took her for a ride to get the oil hot and more thin. I then parked it and lifted it up and found the leak. It seems that its coming from the oil pan seal right at the front case. Those 3 bolts are tight but not stripped and has silicone under neath it but it still leaks. It only leaks as the oil gets more thin and hot. Any options for fixing this without having to drop the entire pan?? Can i lower it a little bit and then razor blade away the bad silicone and put some new silicone in there??? Or will i have to drop the entire pan and fix it that way.
When you get the pan off check the gasket surfaces for gouges. Those pans can be tough to remove sometimes, so I wouldn't be surprised if someone just jammed a prybar in there and marred the surface.
  • For sale 1g Used 1991 Turbo Engine Control Harness, Auto, with ABS
    Used engine control harness for a 1G turbo, automatic with ABS vehicle, replaced any broken...
    • 19Eclipse90
  • For sale '90 Laser turbo
    115,000 miles. Bought new, lovingly cared for. Very low miles in recent years, mostly in storage...
    • GregPLT
  • For sale 2g factory torque converter
    2g Auto GSX factory torque converter
    • pottersgst
  • For sale JFH REAR
    JFH Auto LSD REAR
    • pottersgst
  • For sale 420A OEM 2G DSM 420a Fuel Injector Wire Harness
    $15 + shipping/fees PayPal, Zelle, Venmo, Apple pay
    • Stizzydrew
