slave cylinder, and master done BOTH what do I DO!
J95GST
68
Jan 27, 2005
cocoa, Florida
okay
I just put in new slave cylinder and master !!!
and my clutch pedel still sticks to the floor i have bleed it about 4 times, and it still will still stick to the floor and i have to pump it back up.
and when i am drive for a while, with out shift i'll go to push the clutch in and it will just drop to the floor, what is it,,
I just put a new 2600act, clutch in too, ?!? help please
id look at and mabye replace the soft line from the wheel well to the slave cylender it may be cracked or broken slightly, allowing pressure to leak off.
replace with a good ss braided line from turbo trix or someting.
  • Wanted 6 bolt NT water pipe
    • chrisman287
