Simple Electric Problem. (Fuse?)
LookDadNoBdyKit
237
Jan 2, 2005
San Diego, CA, California
My turn signals are not working. They dont click on the dash nor do they light up on the dash or outside. The light to tell you high beams are on isnt working either. Any idea whats wrong and/or what fuse I blew? I checked the 10A fuse for tails and the 10A fuse for turn signals and they were both fine.
have u made any mods to your dash?if so look there frist then check all fuses.could be short some were but not likely.i dont have my stuff with me its all at the shop.check all fuses i mean all.if there all good could be relay.that is if you didnt make any mods on the dash like lights or turbo timmer.
1993eclipseGS said:
I remember my hazard switch was messed up, And that caused the turn signals not to work, As soon as I replaced that little button, They worked again.
Thats it probably. I have my hazard switch un plugged right now since I dont have center console on. Ill check it out tomorrow morning
Thanks
