2G Should I add oil to AC compressor?
CarlosFley
8
Oct 13, 2013
Alameda, California
Hey guys, my car came with most of the AC components installed but the lines were not connected, and belt was missing. I’ve replaced all the o-rings, the dryer, and a bad schrader valve, as well as vacuum tested the system and it holds a vacuum. My question now as I’m getting ready to finally charge it for the first time, should I add PAG46 oil? I know adding too much oil will create problems but I also don’t wanna potentially ruin anything from lack of lubrication. Is there a way to know how much oil is in the system safely? Any input helps, thanks guys
The only way to know for sure is to take the compressor off and drain it completely then flush out the condenser, evaporator, and lines. Even though AC machines have the ability to remove oil it never gets all the oil so it’s still going to be guess work unless you flush the system, and add the correct amount of oil for the entire system.
Yeah after talking to @CrackedDSM I think I’ll at the very least remove the compressor to flush it and oil it, won’t be flushing the condenser but I likely will the evaporator
Is the condenser new? If it was me i would just replace it now since you’re going through all of that work and the system is empty.
