Shimmed rear for camber, made it worse??
ChiGGz
280
Aug 29, 2005
Toronto,
My tires are almost bald down to what looks like the belt or w/e is in there. So I have a new set, and before installing them I wanted to camber the rear with shims.
The passenger side is fine, looks alot better, probably not enough though, but the drivers side looks like hell. Seems like it got even worse after the shims?? I used 6 washers for each bolt. Could this be something wrong with the assembly? some kind of joint or something thats gone and needs replacing?
Could it be that my inner wall is so worn that its effecting alignment?
its a 2g GSX with what looks like a 1.5-1.7" drop. 18" rims
Thanks
When I made the shims for mine, I used the adage "1/4" of shim per 1" drop", which was told to me by Todd at Ingall's. I had a 1/2" spacer added behind my camber kits and they align up at -0.07. Fronts at -0.05.
Although camber is not the critical factor related to tire wear as much as toe is.
Getting it aligned properly and no just "eye balling" it will make a world of difference.
oh definitely will get it aligned. I'm just eye balling it as best as I can so there won't be too much when I get my number from alignment.
But the one rear side looks really really bad..almost worse! While the other looks much better.
Don't they have Harbor Freight stores in Canada?
  • For sale 4G63 Race parts.
    Brand new seal in box Kigglys HLA 175$ Brand New GReddy timing belt no box 175$ Like New Magnus...
    • GST2012GSX
  • For sale 2g 2G Black Steering Column Plastics
    2G Black Steering Column Plastics $35 + shipping & paypal feesYou must be registered to see...
  • For sale 2g 2G AC Delco Starter ( Tested & In Great Condition )
    2G AC Delco Starter ( tested ) $45 + shipping and paypal fees* fits 2G GSX & GST with manual...
  • For sale 2g 2G Black Center Vent & Switch Plate
    2G Black Center Vent & Switch Plate $40 + shipping & paypal feesYou must be registered to see...
  • For sale 2g 2G Hatch Seal
    2G Hatch Seal $35 + shipping and paypal fees* some small imperfections but still solid with no...
