FoXracing82085
- 95
- 2
- Nov 23, 2010
Lynchburg,
Virginia
I have a 96 Eclipse GS and the steering wheel shakes and vibrates (not violently) when reaching speeds in excess of 65 mph. Also, the vehicle tends to pull to the right, normally at around 40 mph plus. Here is a list of what my mechanic has replaced over the last year, hopefully this narrows it down.
Inner & Outer Tie Rod Ends (Driver & Passenger Sides)
Rack & Pinion
All Motor Mounts
Front Passenger Side Wheel Hub Assembly
KYB GR-2 Shocks (All Four)
All Wheel Alignment
What could be making my steering wheel shake and also make the car pull to the right? Could bad bushings somewhere make this happen? Also to add my CV shafts, both sides, have not been replaced. I have all 4 new tires/wheels which are balanced as well. Any help would be greatly appreciated!
Rack & Pinion
All Motor Mounts
All Wheel Alignment
