shake at around 55
josh1095
Banned Member
453
5
Aug 27, 2009
st. jacob, Illinois
hey all,
k all stock, aside from a brand new built engine. half shafts look good. manual tranny.
have put about 50 miles on it so far. noticed a shake at around 5o-55 mph. had the front tires balanced. not much of a change.
im using prothanes all around.
that obviously makes me feel every vibration from the engine. do you think it could be my rear tires?
it happens accelerating, decelerating, out of gear coasting. anything around 55 and it shakes. has plenty of power so i dont think im hearing a miss.
ya, that and a new set of tires, preferably matching ones! just gotta get thru the break in period b4 i dump another penny into this car, then new tires and alignment. ill just deal with it for 1000 miles during break in. no big deal
because its at a specific speed i would guess its something rotating. check the balance on all your tires. check your wheel bearings, driveshaft and axleshafts. anything rotational and driveline.
Might seem dumb, but make sure your rims arent bent, i had a very similar problem from 55-60 there would be a shake and one of my rims was bent. Bought some stock gst rims and havent had the problem since.
ill check that too, 97tsi. prob just rotate tires from rear to front tomorrow to see if the problem follows and feels the same. if it does, prob alignment or wheel bearings. body has 199k miles on it so its very possible wheel bearings are bad. they r easy in an eclipse. btw ALL balljoints dont look good but also on the other hand they have no play in them. its cosmetic from what i can tell
