Severe electrical problem.. Need advice
Status
Not open for further replies.
spyder97gs
777
6
Dec 10, 2004
Greencastle, Indiana
So lately my car has been acting strange volt wise. I decided to go out today and I added a 4gauge ground wire from the alt to the block. I went to hook the negative back up on my battery and it shot HUGE sparks. It tightened it down and everything and went and started the car. Starts fine. I tried to power on my CD player, no power.. hmm maybe a fuse, no problem. Well I went to turn the lights on and they come on, well my horn/alarm goes off and becomes a constant horrendous roar and willnot stop and the lights will not turn off, unless I disconnect the battery.
I disconnected the new ground wire and it still does the same thing. Any ideas guy? This one has me stumped, and worried. Thanks
Why r u putting in a ground wire on alt? The alt bolt into the block is far better than any 4 ga wire. If you want a bigger ground wire put it between the block and car body and/or block to battery negative.
I was under the impression you could add one from the alt. I linked the problem to the blown 100amp fuse and got it replaced. It's running fine now. I was having voltage problems.. anyways I tightened the ground on the alt. up and seems im not having voltage spikes right now.
EDIT: well it looks like my idea may have worked out right, had I placed the wire in the correct spot on the alternator. I strapped it under that red cover. Guess thats a big no-no.
Status
  • For sale 98 GS-T for sale
    Here is my 4g63 7bolt fully built for sale
    • Yahdin2G
  • Wanted 4G63 Mpi relay
    Looking for a 95 eclipse gst mpi relay
    • SquatchinGST
  • For sale 1g 92-94 Mitsubishi tail lights
    These were take offs from a new GST on a road race team. I had got boxes of parts leftover...
  • Wanted GVR4 3000gt vr-4 gen 1
    Looking for a 1st generation vr4, preferably 1993 due to the 25 spline output.
    • Pressterra
