98RedGs
- 6,239
- 7
- Sep 14, 2002
Bogalusa,
Louisiana
eclipse4wd said:love the setup.looks like my wish list.
. just curious how much this all hit you for?
I think we're both wondering this.
95TalonTuner said:tranny installed before motor? interesting.
1fast97gsx said:Hmm I was going to put the motor in first and then the trans but maybe this will work for me too. It fit with the timing cover and all your accessories no problem then? How much did you have to angle the tranny upwards do you think to be able to get the motor to line up and slide into it? Also .. you just pulled out the bolt in the center of the front and rear mount right ( so 2 bolts total for 2 mounts ) and then let it all down together and then just put those bolts back in? I just wanna make sure nothing will bind up or get caught on something before I try this. Thanks.
44pirate said:I've installed the motor both ways. It's easier, by yourself, to put the tranny and motor together. You have to keep the pullys off however. So after you have the motor and tranny in you have to install the pullys and belts. My $.02
EvolvingGST said:Maybe I am blind but I didn't see an Upper I/C piping on the mod list
1fast97gsx said:The timing belt and covers can be installed already though right? If so then that definitly seems like the easiest way to do it.
