Setting base fuel PSI on AFPR w/ Automatic 1G?
ltvarney
514
Jan 7, 2003
Lansing, Michigan
I have read that the AFPR should be set to 37PSI. I've also read that 1G autos run 43PSI stock. My question is when I setup my AFPR on my auto 1G should I set it to 37PSI or 43PSI? I read in the forums but have not found any clarification on this.
Thanks in advance.
Dsmlink will not set the pressure, you still have to do that. Set it around 42-43psi.
Thanks, will do. When I mentioned DSMLink, I meant since it loads the manual code, I was planning to set it for the manual PSI :cool: I'll make sure she's warmed up and set the PSI to 38 as suggested:thumb:
actually, as i understand it, most injectors are flow rated at 43psi of fuel. so why not set it to 43 and get the most out of the cc rating. you've got dsmlink to compensate of you run too rich.
    • dsmmario
    • Detail
    • dsmmario
