TSiBill
- 0
- Jan 10, 2006
oswego,
Illinois
perviously i had a 50 trim turbo with 625 injectors, 255 fuel pump, fuel regulator, fuel rail, fuel lines,S-afc2, hahn front mount, tubular manifold, Forced performance stage 2 cams, and some other misc. mods. When it was tuned on a dynojet dyno it only put down 304HP and 289FT-LB at 19psi with a very late spool. I was told that the results were so low because the turbo was a hybrid so the comprosser housing was mitsu style and it was just a poorly built turbo. also they said that the injectors could not handle more.
I now just switched over to a PTE gt3076r and replaced the injectors with 880cc and after the tune it it put down 324hp and 299FT-LB at 22psi and still with a late spool. The shop told me that that is about 50hp under what was to be expected. also there are no boost leaks, and both a compression and leakdown test showed the engine to be in fine shape. The shop now says the low results could be caused by the injectors being too large, the afc not being able to set enough correction on them, or the cams having to much lift and duration for the turbo.
I am hesitent in deciding what to do next because last time the shop blamed the low results on the turbo and now it is still about 50HP under expected. So please any advise would be greatly appriciated
so you might want to get confirmation from folks with real experience.
