2G Separation between quarter panel and door on exterior 2g eclipse
RjDSM99
Jun 3, 2021
New Braunfels, Texas
Hey guys There is a pretty good bit of separation between the right fender panel and right door going outwards on my 2g. Only on the right side. Got any ideas on how to fix this or what the problem may be? Thanks
What your refering to as the "front quarter panel" is actually called the fender. Not ripping on you. Just letting you know as you'll get more helpful advise using the correct term. It probably just needs to be unbolted and re alighned. When you try to re-alighn it make sure not to open the door too fast. If the fender gets too far back the door will catch it and can damage the fender pretty bad.
Hopfully a body guy can jump in here and may be able to help you more than just telling you it needs to be realighned tho.
Jesus yeah sorry been a long day, thanks for the help
