tstkl
- 3,890
- 76
- Feb 10, 2005
SoCal,
California
I'm converting my 88 conquest to 4g63 as well as cleaning out my garage, so heres some parts I'm selling:
4g63/dsm related:
Aftermarket lower intercooler pipe, polished, jpipe and 90 degree elbow for a smic, but could be used for an fmic with the addition of a 90 degree. The jpipe is 2 or 2.25 inches and the 90 is 2.25 or 2.5 inches. 60 shipped
brand new unused 2g awd clutch fork and pivot ball 50 shipped
stock turbo drain tubes 20 shipped each (2 of them)
1g stainless steel clutch line 20 shipped
90 oil filter housing 60 shipped
0-30 psi boost gauge 30 shipped
unmodified dsm 1g intake manifold 40 shipped
phantom autometer large water temp sensor 30 shipped
1g awd dsm polyurithane motor mount insert, front mount only 20 shipped
90 short shifter 30 shipped
90 factory shifter 20 shipped
oldschool apexi turbo timer 30 shipped
oldschool apexi super avcr without solenoid 40 shipped
external oil cooler kit for a 6 bolt (oil filter housing, -6 an adapters, pushlock fittings, lines, and oem oil cooler) 100 shipped
1g motor mount brackets. The one that holds the timing belt tensioner, and the one that holds the power steering pump. 5 bucks each local pick up. I also have a second bracket that holds the power steering which has been lightened for rwd purposes.
**CONQUEST RELATED STUFF**
88 ecu, wiring harness, starter motor
I also have the clutch pedal/brake pedal related stuff and master cylinders, and ALL of the abs system and the head unit thingy from the a/c. (clutch pedal, clutch master, brake pedal, brake booster, brake master, etc) Im probably forgetting some things, but thats most of it. ALL OF THIS IS FREE IF YOU CAN PICK IT UP
t-56 transmission related stuff
I also have a stock camaro clutch master cylinder and possibly some other stuff. < FREE AS WELL
4g63/dsm related:
