talon84
- 0
- Apr 19, 2005
metro,
Minnesota
has any one installed a 4 pt harness latley and if so which do you preffer. am going for saftey not looks.... thanks...
Despite the huge jump in safety, you may find that real harnesses are illegal for road use if you're in a mandatory seatbelt-use state.talon84 said:has any one installed a 4 pt harness latley and if so which do you preffer. am going for saftey not looks.... thanks...
Been awhile since I looked it up, but IIRC, the national belt law goes something like "must be DOT approved or pass a 2000lb static pull test"...1LE said:It's true that it's a bad idea to wear a real harness in a car without a roll cage. Compression of the spine is a bad thing.
